Please tell me what could have caused my exige to ‘run-on’ today at the end of my last two sessions at Knock-Hill. The car was very hot and refused to stop when I switched the ignition off… running on for a few seconds of its own free will.
I very much doubt that I have got significant carbon deposits leading to detonation (could I have??). I was running Optimax… and usually do but am not averse to other fuels when weekly commuting.
What should I check… easy things??
he car was okay on the way home when I stopped for fuel refill (Esso Spr BTW) and when I got home.
Possibly with the car as hot as say and then the problem going away when the car was cooler then I would suspect a sticking relay in the ignition circuit.
Simon
Thanks - what colour is a plug that’s been running too hot? also I guess you are saying that my running-on problem might be due to plugs that are too hot and therefore I need to change to a cooler one?
The ceramic insulator nose around the electrode will be very white if its running too hot - usually a brownish colour - but if you are running the correct grade of plugs why would that be unless one cylinder was running weak ?
Would suggest a change to new ones anyhow and see how it goes … maybe just a duff one
I have replaced the plugs - the ones I took out looked okay tho’ if anything maybe a bit rich…but I had been running around (normally) without bother since so i guess the colour check would need to be done immediately after the problem as prof scuffham says.
I’ll see how it goes at the next track day. liked yer video btw.
Does the car shut off on it’s own or do you have to turn the key off again to get it to stop?
My buddy’s 190S has a bad ignition switch and he can take the key out and the car won’t shut off. Luckily, our cars in the States are all fitted with master kill switches.
Meat it shut off itself after what seemed like maybe 2 seconds of running on. I’m pretty sure its not a ignition keyswitch problem 'cause it has only happened twice (at end of my last two sessions at Knockhill)
I’ve been in touch with Champion in an attempt to have them give advice on colder plugs… but they haven’t replied yet.
