Running like a dog
Evening everyone
For the past few weeks the idle on the car has been a bit dodgy when pulling up to a junction and stalling, and yesterday the car wouldn’t start at all-battery full,cranking but not catching. I removed the fuel pump fuse tried again and it ran for a few seconds and cut out. Put the fuse back and it ran fine. Today it started but when pulling away its backfiring big time after 3000 revs its better but if you floor it it bogs down but no backfiring. i’m thinking the TPS as a likely culpret? spark plugs were replaced 4000 miles ago so are fairly new. Anyone ant other ideas?
have you got an Emerald on it?
Mine was just shite b4 fitting it (12deg out on inlet pulley didn’t help either).
Does sound like something else as well?
Mine was bogging down when pulling away and stalling when hot etc…
No problems at all since fitting of Emerald
No emerald on it. Yet Only just started though so cant imagine its anything too drastic reg the timing. Seems its getting too much fuel in it for some reason.
Mine supped fuel and one stank after 5 mins inside. Gave me headaches etc…
Emerald did make a big difference
good luck
