Rotational scraping sound
I’ve noticed at slow speeds that I can hear a rotational scraping sound coming from the back of the car, like a metallic swish swish sound. It seems to be getting louder. I’m guessing the sound is still there at higher speeds, it’s just drowned out.
It doesn’t go away if I put the car in neutral and it is more pronounced when I turn right, and fades when I turn left, so I’m guessing it’s load based.
First thoughts are driveshaft or wheel bearing… but I always thought bearings grumbled rather than scraped.
Ideas ? I’m guessing jacking it up will remove the load and therefore I won’t be able to reproduce it ?
Still there when you brake ?
My money is on a wheel bearing. If there is no play with the car jacked up, undo the big nut in the middle and see what happens.
Have seen a few now where they are fine when tight, and pretty much fall out when the nut has the tension released.
Could be as simple as a wheel balancing weight catching the bottom bolt of the hub mounting. This happened to me last September, & took a couple of days to figure it out - I too thought it was either a wheel bearing or a dodgy cv joint so was well chuffed in the end! :wink:
Could be a loose rear driveshaft/hub nut?
Makes the pad catch on the disc
Sorry, I should have mentioned that earlier, yep braking doesn’t seem to make any difference.
I have a sort of swishing/ticking sound I hear when I’m on the outside lane of the motorway, it’s just the pads resting against the rotors because touching the brake pedal even very slightly changes it from a swishswishswishswish sound into a constant swiiiiiiiiiissssssssssshhhhhhh sound.
yeah then its most likely a duff bearing as John said …
so it’s load based. does that mean it goes away when you put the car in neutral but is otherwise constant, or does it seem proportional in frequency or intensity to either road speed or engine revs ?
if no to the latter then you may have something resonating around the exhaust, such as a connection in the system or a bit of heat shield making contact.
i have this. it annoys me but not enough to get off my arse and do something about it.
It’s proportional to road speed, rather than engine speed.
I’ll check for fouling of the wheel, then check the bearings.
I had similar one recently when the brake cable clip on the wishbone was catching on the wheel weighs, there was a witness mark on the clip. Cheap fix to that one!
Less likely here as it occurred more under cornering.
Cheers, Ian :slight_smile:
