Despite the bun-fight that will ensue, it never ceases to amaze me the fuss made by fokes dremmelling their letterbox. “It makes a huge difference” is the usual call. I’ve never seen any science to confirm that it’s worthwhile.
I believe the front air scoop area is the most important as the rest will venturi through the smaller hole,it’s a gas not a liquid.
Sorting the mesh, now that would make sense, as would adding more collection area (side scoops)
There was indeed a test done in the States with data to back It up that dremelling the lettetbox made a big incrrase in Airflow …
Was very well documented … may have been lotus talk ??
A good search should find it …
[quote=jfk]There was indeed a test done in the States with data to back It up that dremelling the lettetbox made a big incrrase in Airflow …
Haha, think you might find RLS did the testing. Ask Frank, he’ll comment I’m sure.
The point was about the letterbox, not the “3x airflow with scoops”. That may well be the case, but as pointed out, it was an RLS test! I actually believe it’s a worthwhile mod and have done it myself.
I’ve read Lotus Talk and recall ‘letterbox chat’, just as I recall seeing it here. But I don’t recall anything other than peoples feeling in their water.
[quote=661]Despite the bun-fight that will ensue, it never ceases to amaze me the fuss made by fokes dremmelling their letterbox. “It makes a huge difference” is the usual call. I’ve never seen any science to confirm that it’s worthwhile.
Ok so using your theory if I leave my front scoop the same size and reduce the midpoint to a pin prick I will still have the same airflow due to the venturi effect?
If you have ever looked you can take around a third extra out of the midpoint which will make a difference, also the seals at that point are piss poor and need tarting up.
NOt directly related but it amazed me how small the roof scoop on the Pagani Zonda is - and that is hardly underpowered. Funny old thing this gas flow stuff.
Ok point taken. More exactly the term should be that the reduction in air flow is far from a direct relation to the bottle neck reduction. We’re back to guessing here as I’m no aerodynamacist but logarithmic would seem a reasonable assumption.
Therefore to increase the area by a’third’ would result in single figures % increase in flow
Right then …
Who’s brave enough to post their charge temps with both intercoolers and chargecoolers ???
Assuming of course that those of you with chargecoolers …
A) have no leaks .
B) have a pump that works .
C) have a radiator big enough to cool all that latent heat of your gallons of water .
[quote=jfk]Right then …
A) have no leaks .
Lol … I’ll take cover now [/quote]
Hey is that a dig at me with the pump?
i do remember me saying to Pesky that my car felt sluggish, only to find the earth wire hade been left off the charge cooler pump after they mapped the car
I am more than happy to take readings if we do a test i’m not scared at all
