Ride height Exige S1 street use
Considering all sort of silent policemen popping up everywhere, what would be the best riding height
for an Exige S1 mainly used on street?
Thank you for your advice.
Adriano :slight_smile:
Standard is, I believe, 112mm front/122mm rear.
Mine is set to 110mm front, 115mm rear with Ohlins spring rates of 235 lb/in front, 325 lb/in rear.
I try to avoid roads with policemen (real or otherwise) or any other sort of speed humps installed… :thumbup:
I run standard heights, generally it’s fine but the number plate catches on occasion, I have set it a bit lower as an audible warning. Car park exit ramps can have some steep inclines. Going too low could be a problem with the mot brake tests.
I found this listing:
:thumbup:
