Ride height @ chassis siderail??
Hello
What is the chassis siderail? I wanna check the ride height of the car but doesn’t understand where they whant me to measure it. I think it might be the rail where the front and rear jacking points are. According to this the car is 10mm too high. Help please…
//Ren�
It is the rail with the jacking points. Measure as it meets the front and rear wheel arches. Make sure that you have someone of equivalent weight sit in the car before measuring as it can make a big difference depending on spring rates. Alternatively put some appropriate weights in the drivers seat.
Aha, yes, now I found it in the workshop manual. “mid-laden ride hight” is explained as driver + passenger + half a fuel tank…have to check my car again then. I gues the SAE 68kg nominal driver is appropriate
Corrected the toe angle to spec yesterday, got a whole new car again
