revs high on start up
Hey
When I start my car it revs to about 2500rpm then reduce immediately down to normal tick over 1000rpm ish. It’s annoying as it makes you look like you’re using the throttle unnecessarily to start the car and also i’m sure it’s not good for the engine long term.
Anyone had this or know how to resolve it?
They all do it, not sure of the reason why? (there must be one though…).
Cant help more than that sorry.
Later maps by Lotus calmed this feature down a bit to say 1.5k to 2k but still annoying none the less :frowning:
Ok well at least I know it’s not just my car, presumably I should be able to get the ecu sorted so it’s only 1.5k? Anyone done this?
Cheers guys
New firmware flash from Lotus or get the Gotham map from Sinclaire it is built in :wink:
