Retro fit touring pack carpeted sills/floor
My car does not have the touring pack, and the G/F is a bit sick of how noisy it is if we ever use it to go any sort of distance.
I’ve decieded to try retro fit the carpeted floor/sills as fitted in the touring pack and a tiny bit if sound insulation - I know it will add a little bit of weight, but if it stops her moaning then I’m a happy man!
Looking on Bell & colvill, I’ve pulled off the following…
Carpet - Drivers Footwell - Black - RHD [A120V0058K]
Carpet - Passenger Footwell - Black - RHD [A120V0059K]
Carpet - Sill - Black - RH - RHD & LHD [A117V0602K]
Carpet - Sill - Black - LH - RHD [A117V0603K]
Carpet - Floor Underseat - Black [A117V0095K]
Carpet - Rear Bulkhead - Black [A120V0042K]
2x Finisher - Sill Carpet - RHD RH & LH [C117U0430F]
Most of the above looks self explanatory, but was a little unsure if the drivers footwell and passenger footwell carpet is behind where the pedals and footrest are??
Anybody else done this, or know of how easy it is to fit?
I can give you most of that…
Which bits do you have??
Carpet - Drivers Footwell - Black - RHD [A120V0058K] [color:#FF0000]YES[/color]
Carpet - Passenger Footwell - Black - RHD [A120V0059K][color:#FF0000]YES[/color]
Carpet - Sill - Black - RH - RHD & LHD [A117V0602K] [color:#FF0000]NO[/color]
Carpet - Sill - Black - LH - RHD [A117V0603K] [color:#FF0000]NO[/color]
Carpet - Floor Underseat - Black [A117V0095K][color:#FF0000]YES both[/color]
Carpet - Rear Bulkhead - Black [A120V0042K] [color:#FF0000]NO[/color]
2x Finisher - Sill Carpet - RHD RH & LH [C117U0430F] [color:#FF0000]NO[/color]
[quote=jonnyfox]Carpet - Drivers Footwell - Black - RHD [A120V0058K] [color:#FF0000]YES[/color]
Cool - PM me how much you want for them.
Cheers.
Nick
Call it a cup of tea next TD :wink:
Top man Jonny :wink:
I,m after a suitcase full of used banknotes if you have any that you need rid of !!
I,m after a suitcase full of used banknotes if you have any that you need rid of !! [/quote]
Just for you Jonny…:smiley: Silverstone Oct…cough!!!
Yep - Top man!
Much appreciated.
John… As a matter of interest, how much does all of that weigh? Can you bag it up and pop it on the scales?
Wondering how much noise insulation it also actually does provide too! :smiley:
I’m going to be taking all of mine out when I get mine back, so I will get it weighed. I’ve also removed all the boot carpets as well, my car is going on a diet :wink:
I don’t really get the removing carpet to be honest. For a road/track car I would much rather have them in and the carpets must weigh virtually nothing anyway. The touring pack does add a big slab of heavy sound deadening behind the bulkhead which could be replaced for something much much lighter though.
I’m planning on installing light weight sound insulation under the carpet and behind the bulk head - the carpet was only really to finish it off. Weight wise it shouldn’t really add anything, but I’d rather do this and go on a diet to save a couple of kg than have the missis complaining.
As it’s you Pete…missing the 2 x sill and behind seats carpet, adding the boot bottom and rear (but not foam) it’s:
And with a few more bits you may recognise:
JF is that a foot rest i see there? Do you have a long term use for it?
I know what your thinking Ade, i still think the misses should just wear massive platforms :smiley:
She does own some, but she is needing stability in the car which her 6" heels won’t give her :frowning:
:smiley: Is that going to JSR on Tuesday as well?
I should start charging for my cast offs :wink:
Where am I going to apply my passenger brake pedal now Jonny?!
[quote=jonnyfox]:smiley: Is that going to JSR on Tuesday as well?
I should start charging for my cast offs :wink: [/quote]
Yes please :slight_smile: I’ll buy you some beer when we are at Spa :wink:
MARKY…B :smiley: Are you in the country…?
It’ll get be there Ade.
