Anyone moved their remote reservoirs from the lower wishbone?
They are pretty exposed to road grime and debris down there (which I feel will have contributed to the failure of one of the braided hose ferrules at Anglesey). The rears were in much better condition.
I’m thinking after rebuild to reposition them. Maybe service access panels with quick release etc…
You should do your measuring etc, befor ethe rebuild, you can then request the correct sized hoses and have them all come off the damper and reser at the correct angles.
My front ohlins are positioned on the chassis by the lower front wishbone (dealer fitted, but as per factory advice). I should have put some protective tape around the canisters first but hey ho.
They do look very secondhand after the bad winter too
The 2-11 has them attached to the front crash structure. It may be worth looking at something similar although you would probably have to cut a hole in the wheel arch liners to run the hoses through… Only takes a couple of minutes to remove the liners so easy enough to adjust when you need to (me personally once I have found a setting I like I dont touch them.)
