I’m sure this is dead easy and it’s just me, but I want to swap the aftermarket Alcantara steering wheel that came with the Exige for a snap off removable one having been able to collect all the pieces I need.
I removed the steering wheel and the nut onto the column and thought the old hub would just come off. But it’s on there rock solid. I don’t want to force anything as it feels this is me not the car!
I can’t see any other bolts etc. Anyone else done this is there a trick or something I’m missing?
It’s a tapered spline so either get a proper puller or bolt the wheel back on and put the nut on a couple of threads (so it doesn’t smack you in the face!) And then wiggle the wheel at the 9 and 3 position till it pops.
This works well, get your legs under the wheel to push and pull with your arms but DO put the nut on or it will hurt a lot and you will have a wheel imprint on your face!
The problem with the puller is you may (will) bend the impact cage that it’s braced against, I have done that! You will have to bend it back into shape.
Thanks for the advice really appreciated it. I kept wiggling it without success. So reverted to my home made puller but braced with a couple of spanner so it couldn’t bend. When it eventually popped off I did nearly ***t myself at bang
Wheel now swapped, snap off fitted. Think I’ll be dying the red to black otherwise we’ll chuffed.
I used a combination of a balljoint splitter (take it apart, use only the one half with the threaded bit), large washers on the end of the column/securing nut to protect it and spanners to brace against the cage. Using that contraption to put a constant tension on it I pulled, wiggled and gave some taps with a rubber hammer on the back of the steering wheel. It’s scary though, especially if you read all the stories of people collapsing the steering columns!
Your car is identical to mine, yellow, snap off and red wheel. That’s how it left the factory. It had a omp flat bottomed wheel when I purchased it which I could not get on with on the skid pan at Rockingham. I had a red wheel in my spares box and swapped it.
If I ever get round to getting a snap-off wheel (and I’ve been thinking of it for a decade), I reckon I’ll just take it to a “man who can”.
Entertaining read, glad you escaped injury
