Removing rear inner panel
Hi
Been doing a few things on the Exige
Has anyone removed this black panel
Do I need to remove the pop rivets ?
are the sliver panels on the side (not the spoiler mounts)normal on an Exige
youll have to remove or at least support the exhaust. so diffuser off. to do that.
there is normally a bolt going through from the back of it to the rear clam behind the numberplate which will need removing
then you’ll need to drill out the rivets which hold it to the subframe. after that its a case of wiggling it out of place, with exhaust gone it may be easier to get it out the bottom but can be done via the top
Thanks,
