Changing the discs and hoses last week - ready to bleed clutch so removed air pipe ( going into a carbon airbox ) and found a big metallic ring down the bottom next to the filter.
Tried to get the airbox off, 2 easy bolts at the top came off - bent box back enough to see its one of my trumpets that has come off
Are there 2 more bolts underneath the airbox that are a bugger to reach?
Got 3 bolts out, cant get the one nearest the air pipe
All the screws that are holding that vertical metal sheet nder the airbox ( is that the retun bit? ) have rusted up, will not budge
Left them covered in WD and will see if anything happens tomorrow…
Well thats all full of WD now, might have to resort to the drill though - does that bit do anything special or is it just a nod towards keeping the rear a bit cleaner?
I dont use the boot to carry anything so could remove it or leave off for a bit…
The trumpet bit I have is smooth, and I can see the hole, just - cant see how it would be locked in place though.
Dont have camera on me, i’ll post a pic up later on though
Good job i’m messing about with it now, have no tyres left after elvington on saturday so cant go anywhere…
No flanges on the original Simon, you must be referring to Jenvey ones.
The originals are held in place by the heads of the three screws around it. Yes, I know, bad system.
Better go and find some washers to make the shoulder effectively wider. Your trumpets must have been machined slightly on the thin side, so they worked loose.
Cheers Uldis - I twisted the box enough ( only 1 screw left now…yay! ) to see how they are attached.
Still no joy in getting the 5 screws that hold that metal plate in, drilling time tomorrow…
Drilled 3 screws/rivets off - before I bash the rest of them, can this part be left off? - if so I wont be too worried in getting carried away with the drill…
If you damage thr aluminum thread you can always put one back, it’s caled a Rivnut.
OTOH, to avoid these problems I replaced the normal Philips bolts with alloy Allen head ones, so they won’t rust and ypu always have a trusty allen connection to undo them.
I replaced the boot return ally panel bolts with plastic ones (for holding interior panels in place) from Halfords last time i had it off… because one of my originals was stuck solid… used heat and mole grips to get it off.
