Remote thermostat
Anyone fitted one one of these to an aircon equipped car. I know most have junked the aircon but I would rather keep it at it works to a fashion and I’d rather have it than not.
I know its been discussed in various threads before but I can’t find a definitive “YES” in any of the previous threads. Mind you I could have missed it !
Any help would be greatfully appreciated as I’ve got some mods to do befoe the Donnington day and this is one of them.
Thanks,
Con McL
Yes, the Elise parts (the only one I have any experiance with) remote thermostat WILL fit on an A/C equiped car.
Sean…
Sean…
are you sure? I thought as standard it uses the heater circuit as main bypass flow…
Absolutly 100% positive!!
It does use the heater as the main bypass flow, you just need to cut the hose to suit and it all goes together a treat!
Sean…
Sean…
hmmm… IIRC the A/C cars have a valve closing the heater circuit when the cabin controls are set to cold (it does also make sense, if you want a cool cabin). IMHO it is possible to make it work, but the bypass should be re-routed with a new hose.
cheers
Carlo
-edit- I mean to make the A/C work, I agree the thermostat will work
