Rear wheel spacer?
Im trying to work out on what wheels to buy for my car currently and just need to know something as its hard to tell from the pictures.
If your exige rear wheel was 12mm further out, would it still clear the bodywork or would you need to trim in the inner lip.
Also its hard to see but even if it would touch would the suspension compress that much to cause it.
Im currently looking at either going for 16x8 et -3 or et-13, -13 would put the wheel 12mm wider than out than the stock exige.
Im just thinking if I can widen the track as much as possible then I may aswell do so, it will also allow me an even wider diffuser
Whilst changing the offset will increase the track, it will also alter the geometry and increase loading on the suspension components so don’t forget to allow for that.
I would suspect 12mm is going to be enough for the sidewalls to foul on the arch lip.
