How do I remove it off my Elise? It is so wobbly it is impossible to see out of, help…
Hi Mate.
I believe the mirror ‘mount’ is actually glued onto the windscreen, so I am guessing the wobbling is at the mirror end of the mount.
Perhaps a dollop of glue at that end…?
The mount is firm on the screen, the mirror itself appears to slide onto the mount but I can’t work out how to release it so it slides off
Pull it, should just pop off!
There should be a small grub screw just under the arm, loosen that and slide the mirror up. The foot will stay bonded to the glass. Then you can open up the plastic covers on the arm and tighten up the screws.
There is a little hole where a grub screw could have been, doesn’t seem to be one in there, I’ll look a bit herder over the weekend
