Rear spoiler fixing
Hi All
How did Lotus fix the the blades to fin on the rear Lotus Exige spoiler ??
Paul
Which spoiler are you talking about? Pics might help.
Its a standard Lotus rear spoiler the end plates bolt on but the 2 middle supports must glued in some way were they connect to the blade
Paul
So it is an early S2 rear wing then?
Yes guys from a MY00
have you tried looking at DeRoure exploded drawings might give you a clue.
Silly thought …is there a long bolt running inside the supports which is exposed when wing is removed from engine cover??
No it appears they are bonded on with an epoxy glue :slight_smile:
