Rear diffuser?
Is the rear diffuser made from aluminium or steel? Thinking of filling in the exhaust cut-out when I get the single outlet done.
Its ali.
If you want to fill the gap then drop me a pm next weekend - I should be able to get you a full pre preg carbon diffuser without holes and save you a load of weight too. My mates just knocking a batch up now. I couldn’t bare to cut a hole it so I think I’m going to have to sucomb to a 2bular exhaust and a panel eliminator kit…
Have you got any photos of the diffusers ?? or can you get one ?? Do they match the original or are they extended ?? If they match the standard one then I may be interested too, for the same reason.
I’ll get you a photo asap. Its std size at the moment as thats easy. Extended ones are in th epipeline.
That sounds good, let me know when you get the photos.
Hi Badnis
I am now in the market for a new rear diffuser for my S2.
Prefer one in carbon with extended wings etc.
Need to have the cutout though - not sure about changing the current stage 1 exhaust.
Reverie look like the only current option unless you can help or suggest a alternate
Chris
I am still interested in a std CF replacement too…
There’s a lot of worked needed on the diffuser. I’d go with a Reverie one for the time being. I do need to go and collect mine though and finish it off…
