Rear brake line length....
when running front caliper on the back via bracket, anyone know?
Want to order some lines with a banjo end so I can run a second bleed nipple on the inside edge
Think mine are the standard length, even with the 315mm discs
If you are getting a set made I’m after some too. Haven’t got round to it yet. Was also going to go with a banjo.
just need to sort the routing, might look again tonight at going across the top wishbone
Get some of this
Use it to make up dummy pipes to get the exact length you need. Worked for me.
Will
The standard front banjo hoses fit perfectly on the rear with two pots (did it on mine)
you got any more dave?
