Example: Braking from 100 km/h to 50 km/h… How much should the braking force be on the pedal all the way from 100 to 50??
Dumb question maybe…??.. But I often lock up the tyres in the end of this example…(only way to avoid it is to use less force in the end)… So im a bit qurious if there is a formuala for this (graph)???.. maybe at 50 you should use 75% of the force you had at 100…or smt else???
doesent really matter that much … but im a bit curious how the realtion between speed and braking force works…
