Help me please dear kind Exiges.com experts!
I have just had my front disks replaced, with new Pagid RS14 pads, front passengaer side wheel bearing replaced, and a full set of Toyo R888’s fitted and balanced. Finally, I had the car fully geo checked and adjusted.
Initially, everything was fine, and then a rattle started on the passenger side front wheel. This rattle was intermittent - sometimes it would not be there, and then hit a bump and it starts again. Over time the volume increased, and it occurred all of the time, with the rattle increasing in frequency and volume with wheel rotation speed.
This problem appears to be brake related, as the slightest pressure on the brake pedal (and not to the point of actually braking) silences the noise. My garage stated that this was due to the set of pads on this wheel being a fractionally different size (I take it this means smaller) than normal, meaning that it rattles around in the caliper.
The car has been back to the garage twice now, and the noise does the same as before - OK for a few miles, then increases to full volume. Apparently some form of ‘sticky spacers’ have been applied - but on investigation this just appeared to be a lot of copper slip. In desperation at the weekend I attached some sticky bits from Elise Parts to the back of the pads in question (actually meant to stop brake squeal - and left over ffrom a previous pad change), but this made no change.
The car runs and handles great. No vibration in the steering column, chasis, or brake pedal when braking hard.
Do you guys agree that this seems to be due to ‘funny’ size pads? Have any of you had the same problem, and how did you solve it? Do I need to buy another set?
I have just come back from a round trip to Scotland to see the Scottish Elises guys weekend before last, and was ready to commit suicide with the noise. I hope this can be sorted out before Classic Le Mans comes along!
Please help.
Most appreciated,
Clive.
