rattling noise in sill
Are there cables/pipes running through the sills, has anyone else found them rattling.How do you get access into this area, do the top covers come off ,if so how.
many thanks in advance.
Are you sure it’s in the sill? There is a panel that the wheel arch liners fit too with the vents in behind the front wheel. Stones can get in here and rattle around, you may be able to see them behind the panel gap. I think removal is the front undertray, a bolt or 2 underneath and one behind a plastic panel under the door hinge.
Never taken the sill covers off, presumably they’re sikaflexed on?
Sorry about the poor quality, but I recorded Wrecks to Riches where they were repairing a VX and they had to cut away the sill…
I have noticed that the sill does heat up sometimes, so I assume that its the pipe in the picture.
thanks lads i will have a look and see,sounds like cable/pipe rattling against alloy sill
I get the same thing when the whole car is hot like towards the end of the day when driving on the continent. I’ll be interested to hear if you have any success.
