Hi all,
Does anyone on here run the radium twin can setup on there exige?
I’ve been looking and it looks like some modification is needed to the fuel hose?
It doesn’t state this on the website but some have said there is a clearance issue?
Hi all,
Hi,
I don’t have the Radium ones, but the Saikou Michi twin can set up fit really well and you don’t need to modify the fuel line. I got a set with the optional ball valves.
You’ll get new hoses so no need to cut the original ones. From now on you will also get a fabricated adapter and a pice of larger hose - if you have a large throttle body fitting, like I do.
Michael
Cheers Michael,
I emailed them but are currently on a 10 week lead time.
Which would take it to mid August at best. The radium cans on on the shelf. I was going to buy the qwk cans from sector111 through Dave but that would require cutting my intercooler heat shield as the top pipe would foul
I have the sector ones and a RLS heat shield which didn’t need cutting.
