maybe usefull when you need to replace them as i found out today
i needed to replace my radiator and aircocondensor and as i already had bleeded both aircon and cooling circuit have decided to replace both fan’s as a precaution
found out that my local radiator and aircon wholesaler have these in stock as it’s a universal fit also with the same plug as used on the elise/exige
a new fan costed 57 quid including VAT in Holland, so much cheaper than eliseparts and it’s exactly same manufacturer, in the UK probably same situation, so it will save you a few pounds
aircon condensor only came in at 170 pounds which also is a lot cheaper than Lotus charges
