Race M/S Lotus Elise For sale
No matter how much I want to keep my Elise, sometimes things in life don�t come up as you wish. My plans about what I will do in Greece have changed dramatically. In addition as soon as I will not be able to drive it legally on the Greek roads (needs about �20k to register it to Greece) it is not really worth keeping it. So I have just decided to sell it.
Here is a sort description of the car:
[Bear in mind that most parts have only worked for about 30 minutes in total, so practically new]
General stuff:
Central seating Motorsport Lotus Elise.
Weight: 620kg
Wheels: Standard Exige S1 rimstocks (16� & 17�)
Tyres: Yokohama A048 (plus a set of wet racing tyres)
Road Registered with V5 and easily road legal (CAT included)
Chassis:
Standard Lotus Elise S1 chassis (bought new, LR number)
BODY:
Two M/S rear clams (one in Carbon fibre and one in F/G) & � panels
Two M/S engine covers (one in C/F and one in F/G)
M/S front splitter
Front M/S clam
Oversills
(http://www.eliseparts.com/shop/index.php?main_page=product_info&cPath=169&products_id=635)
Front bonnet
Lightened sills
M/S roof
Lightened doors
Quick release connectors
Carbon Fibre Rear Wing
Aluminium rear wing mounts attached with quick release ball pins to the chassis
Aluminium light front extended undertray (improve aerodynamics)
Carbon Fibre rear undertray
Carbon Fibre 4 element diffuser
Carbon Fibre side air scoops
Carbon Fibre super light mirrors
Interior:
Corbeau Lotus Seat
Six point TRW seat belt
Momo steering wheel (ex Colin Mcrae!)
SPA quick release connector (Protrust Solutions Ltd - Home of Motorsport Safety – Protrustsolutions.co.uk) for the steering wheel
6-point roll cage
Aluminium bulkhead
Custom dash with the Stack display in the centre, Motec BLIND ADL(http://www.motec.com.au/adl.htm) at the left and all switched & circuit breakers at the right
Glass:
Glass windscreen,
Plastic side windows (fixed) with air ducts
Brakes:
Front Alcon 4-pot calipers (Hoerr Racing Products, Motorsport Lubricants, Brakes, Shocks, Springs)
Front 304mm Alcon Rotors (brand new) with aluminium bells
Modified front Uprights
Rear AP 2 pot calipers
295 Discs (Lotus Motorsport)
Teflon S/S braided hoses,
Two Tilton master cylinders (http://www.tiltonracing.com/content.php?page=list2&id=22&m=b) (one for the front circuit and one for the rear)
Tilton Brake bias balance bar (http://www.tiltonracing.com/content.php?page=list2&id=42&m=b) with remote knob (http://www.tiltonracing.com/content.php?page=list2&id=34&m=b) and 90 degrees coupler (http://www.tiltonracing.com/content.php?page=list2&id=44&m=b)
Handbrake
Ferodo racing pads
PLUS (currently not installed): 6 Alcon 304mm Rotors, two bells (used) and a set of front Performance Friction pads (new)
Suspension:
Ohlins Racing 46mm 2-way adjustable Dampers with remote reservoirs & springs
Fully rose jointed wishbones
Adjustable & stiffer front ARB
Adjustable ARB rose jointed links
Rear ARB with adj rose joint links
Rear Lotus M/S uprights
New S2 steering rack
Rose Joint rear toe link kit
Plus:
A set of front uprights
A set of rear (standard) uprights
Engine & Gearbox:
VHPD Engine (Unmodified)
Quaife 5 speed straight cut gears close ratio gearbox
Quaife ATB Differential
Custom engine cooling circuit (more efficient and secure for the engine)
Custom Remote thermostat
Engine Oil Air-Cooler
S/S braided fuel lines and alloy fittings
CAT replacement pipe
PTP
Janspeed Supersport S/S exhaust
Gearbox oil cooler
QED DRY SUMP KIT (about �2k new)
FUEL:
Aluminium light 35lit fuel tank
In tank pump and
Aluminium Swirl pot
Secondary external ATL 200L/hr @ 10 Bar fuel pump (bought from D-T for �511) (http://www.demon-tweeks.co.uk/products/ProductDetail.asp?cls=MSPORT&pcode=ATLKS151)
All S/S hoses and Alloy fittings
Two fuel filters
Dry brake quick re-fuelling system
30lit fuel container
Electrics:
Emerald ECU (Latest firmware)
Custom Vehicle Wiring
Motec Wiring
Many Mil-Spec Connectors
Motec Data logger
Two Brake pressure sensors (one for front and one for rear)
Four Wheel speed sensors (fronts are Motec, but not currently installed)
Motec Steering wheel Angle sensor
Two Engine temperature sensors (one for the inlet and one for the outlet)
Two Engine Oil temperature sensors (one for the inlet and one for the outlet)
Engine Oil Pressure sensor
3-Axis Motec Accelerometer
Throttle Position sensor
Shift lights
Push-able circuit breakers
Powerful (but extremely light) interior fans
Rain light
Light (5kg) but powerful race battery
Motec Can-bus PC cable
Paxton adjustable fuel pressure regulator
Adjustable Fuel Pressure sensor
Fuel temperature sensor
Carbon Fibre 4 Litre Multi-Flo Electrical Extinguisher System (http://www.demon-tweeks.co.uk/products/ProductDetail.asp?cls=MSPORT&pcode=P/EMFE400A) costs �1170! Not installed & Needs servicing (costs about �50)
Laptop for MOTEC and EMERALD connections
PLUS:
TRAILER & tow car
BAD POINTS:
Needs Re-spraying and a few repairs to the rear clam in order to be in a show room condition
Needs attention the Motec wiring
Needs full GEO (although not far of ideal as it is).
[image]http://i69.photobucket.com/albums/i48/GeorgeLotus/DSC08363.jpg[/image]
[image]http://i69.photobucket.com/albums/i48/GeorgeLotus/DSC08362.jpg[/image]
[image]http://i69.photobucket.com/albums/i48/GeorgeLotus/DSC08112-1.jpg[/image]
Generally speaking, the car is extremely fast around the track.
Please, don�t ask me for a price, but just make me an offer for the package (Elise-Saab-Trailer). Don�t worry if your offer is too low, I wont be offended!
Bit of a vid as well
- YouTube.
Hope you don�t mind ; the car really does look like a special bit of kit, spec sounds pretty damn awesome as well.
Thanks David.
The car works well; i am afraid i can’t say the same thing about my hands!
presumably this is not road legal?
From above:
"Road Registered with V5 and easily road legal (CAT included) "
No it is not as i have never bothered MOT it. I might do it in the next few days, though
and a pic of the interior:
[image]http://i69.photobucket.com/albums/i48/GeorgeLotus/DSC08443.jpg[/image]
Forgotten to mention that many Yokohama A048s included, plus a set of rain tyres. The car will be with brand new A048s (fitted today and will be used for a few laps in the wet Silverstone on Sunday) on its rims.
Where abouts in the country are you?
Could you conceivably put this to RHD and put a passenger seat in there?
Hi,
I am in Huddersfield.
Yes, you can easily convert it to LHD or RHD. But why would you ever buy a central seating one if you want a RHD?
Cheers,
George
and a few more photos:
[image]http://i69.photobucket.com/albums/i48/GeorgeLotus/DSC08456.jpg[/image]
[image]http://i69.photobucket.com/albums/i48/GeorgeLotus/DSC08455.jpg[/image]
[image]http://i69.photobucket.com/albums/i48/GeorgeLotus/DSC08454.jpg[/image]
[image]http://i69.photobucket.com/albums/i48/GeorgeLotus/DSC08451-1.jpg[/image]
[image]http://i69.photobucket.com/albums/i48/GeorgeLotus/DSC08452.jpg[/image]
[image]http://i69.photobucket.com/albums/i48/GeorgeLotus/DSC08449.jpg[/image]
awesome car
love the central seating position
Thanks Dean
George,
what rain tyres are they ?
thanks
SOLD.
Thanks
