r888
baby question here, doese anyone know if these tyres can be repaired? have a nail in the middle of the tyer and have heard that some run flat tyres cant be?
Providing its not in the sidewall then yep it should be fine ive had A048’s repaired a few times.
I’ve done them incl run flat
i did use tyre weld init last night, should be fine as well.
Yes - although remember there’s more margin in a tyre replacement than a repair - so if it’s not in the side wall or or on the corners then it WILL repair :wink:
cool as its dead in the center on the tyre
If you have used tyre weld I am pretty sure it will not repair.
I did have my last set of rears repaired although it did bother me a little on the trackday I did on them.
Well got it done and the tyre seems to be ok.Then took half hour cleaning everything due to the tyre weld and took them longer to see how the car gets jacked up even thou I was trying to tell them how to do it thats kwik fit lol �15 pounds cant moan big bloody nail to.
You took your Exige to Kwik Fit ??? :crazy: :crazy: :crazy:
Yeah I was told a while back that a punctured tyre that had tyreweld in it could not be repaired, but maybe that’s an excuse for tyre fitters not to have to deal with the mess inside!
i did look around but the waiting list was ages and they did it there and then. Took them ages, he said when using that stuff you have to clean it out with loads of water. looked like new after. but wont be going there again lol
Fine for road use if it’s in the middle of the tyre, I won’t use a repaired tyre on track. You can repair them even if tyre weld used, just need to clean it off properly.
