Problem with Stack dash - Help
Hi Guys, I have a problem with the stack dash in my car (2000 Mk1 111S) all I get when I turn ignition on is imobilise light and alternator red ignition light, the LCD odo bit does not display, neither does anything else, also rev counter/ speedo doesn’t work. However if I put it in another car everything functions correctly, are there any fuses / other components that may be causing this? Thanks in advanced.
Found out it was a simple fuse that supplies dash :slight_smile:
