Does anyone know if it is more difficult fitting a 60 ltr tank than a 54 ltr one?
I did a 54 ltr tank once and found that pretty straight forward.
Tiny bit more fiddly as the large tank/shape means you have to juggle it a little to get it in, but other wise the same
I keep a 60 ltr on the shelf if you need one!!
Thanks. I’ll have to sell my 54 ltr tank first.
With the 54 ltr tank I was able to fit it with the gear cables in place. I only unhook them from the abutment at the gearboxhousing.
Will it be worth the effort for the extra range another 6 litres will give?
I think my Evora S is a 60 litre tank but I always seem to fill between 50-55 litres, A lighter car with the same engine should be fine with that? Just my 2p.
stock being 40L does need a boost though!
Thanks. I know the difference is only 6 ltrs but I’ve heard the Exige V6 can be quite thirsty. How many Mpg (or km/L
) can you get with an Evora S?
I have seen as much as 27mpg on a run. Low 20’s on mixed driving. 6.7mpg on track.
