Pre cat sensor
Need to check my pre cat O2 sensor.Had a quick look where the sensor cable runs cant see where it plugs into the loom,is it under the header tank somewhere,Cheers.
follow the cable from the sensor and there is a plug approx 12" from the end, it should be clipped up onto the inside of the rear subframe.
Cheers for that info will have a look tomorrow.Did have a quick look the other day,found where its clipped on the subframe couldnt see a plug.
