Ball park figure for how much a set of performance pack Exige seats should cost (if I wanted to put the seats in a touring pack car in order to have harnesses)???
Cheers in advance
Cheers in advance
From just under �400 upwards, each.
Thank you! Is the work easy to carry out?
Harder than lego, but easier than mechano. Just make sure that you check your existing subframes will work when buying.
but 2k if you want real performance pack Lotus seats
ps seats easy to fit
harness bar not so easy as you may have to cut away you plastic rear pannel depending on what you buy.
but 2k if you want real performance pack Lotus seats >
Isnt that the whole pack for 2k???
nope thats for a pair of Lotus seats
Why not buy a bar that allows for bolt on harnesses and keep the oe seats?
Standard OE seats don’t have the cut outs in them that are necessary (as in a safety sense) to utilsise shoulder harnesses.
Totally agree, using harnesses with the standard seats isn’t a good idea as they spread the harness too wide at your neck.
If you want a cheap alternative to changing the seats I’d consider these from Sector 111
[image]http://www.sector111.com/images/products/interior/seat%20grommets/seatgrom.jpg[/image]
Evo,
That looks like a good alternative, has anyone had these fitted?
Those seats that are just under �400 arent available yet.
