Powerflex warning
If you fit uprated engine mounts (stiffer) then be prepared to get the socket set out. Mine have been in now for two track days now, plus milage to and from. Lost count how many bolts I had to tighten and a couple were really loose. Recon I’ll be checking after each track day from now on.
Mine have been in for a couple of years…
Who fitted them? did they torque the bolts correctly?
Mine also two years now and nothing fallen off yet.
Ex77
Which bolts were loose?
Nothing on the engine or gearbox but bodywork and heat shield fixings also the eight exhaust mounting bolts, just thought I’d post findings as I know this is a common mod. and only takes minuets to check (once under trays are off)
Thanks for the heads up, I’ve got some powerflex engine mounts to fit in the next couple of weeks so I’ll get as many fixings checked as I can at the same time. :slight_smile:
