[image]http://pictures.topspeed.com/IMG/crop-460x306/2009_Lotus_Eagle_6w.jpg[/image]
Horrible looks like a cross between an S2 and a europa !!!
thats a slightly restyled m250 that never made production
Deffo not an Eagle… you can see from the disguise that Eagle has “shoulder” vents above and behind the trailing edge of the door, much like the Fezza F430.
Looks like something for the American market ugh !
That’s a photoshopped M250 - and a bad one at that. The M250 was beautiful - that car is not.
Yep the eagle has shoulder vents
A little bit of research reveals that many of the photos of so-called deveolopment hacks are not registered as Lotus cars. In particular the car with the plate KE56 FJN is NOT registered as a Lotus depite many claims that it is the new Lotus - in fact I couldn’t find it at all so maybe that doesn’t prove anything.
However, the following cars are all registerd as Lotus cars :
AO57 EYU, 3458cc, Blue, First Reg 01/02/08
AO57 EYV, 3458cc, Black, First reg 01/02/08
AU08 GHB, 3456cc, Black, First Reg 01/03/08
These cars all look to have family conections to the latest spec Europa, notably the front indicator lens but with an engine size considerably bigger than the Europa that is not what they are.Door handles are different as is the main bottom grille line. They seem to be about M250 size and shape…
and a blast from the past…
AU06 HKN, 3506cc, Black, First Reg 24/07/06
If you put ‘Lotus Eagle’ into the search box on Google Images you will find pictures of most of these cars quite easily. One or more of them could be the real thing…
Some cars have been Esprits and Eagles, allegedly .
From some of the pics I’ve seen to date, it looks like the new car will retain the ‘visor’ type windscreen seen on the M250
