Yes, I hear the coil pack is fragile. It will be a bit of a pain to go and get it from NW when they have fixed it (we’ve got a trackday next Wednesday at Llandow) but I’m glad they are looking at it.
Not much you can do about things like that, still looks lovely!!!
you are correct I parked the car in the garage after getting back from France, 4 days later won’t start. Clean up all the sensors still no luck, check for a spark with a spare plug, appears a bit weak so I call the RAC home start. He cleans up the coil pack, cleans the contacts which are very corroded and the car starts, but suggests I replace it with a better quality one from Demons.
Has anybody changed the coilpack for another make? Or where is the best place to get a replacement?
Simon
Calibra coil-pack is more expensive than the lotus one.
Motaquip VCL625 does the job but you need to switch plug leads 2 with 1 and 3 with 4 to make it work - because the LT plug is connected the wrong way round for us… cost me �41 for one in April… but the really good thing is you will get one from ANY motorfactor. Comes from a Punto or Alfa 1.8 i think.
Got given a few fuses just incase it happens again. Think we’ll book it in again for a week incase there’s something causing the failures, plus a couple of small niggles to sort.
Interesting. It was actually a fuse the last time it broke down. They replaced the fuse, and it broke down on the test drive. Then they found a problem with the coil pack, and changing that seemed to stop the fuse blowing. Guess not
I suspect you’ll be going back again with this one
If it does, get them to check the wiring from the ECU as it passes through the rear bulkhead to the engine. The wiring in mine got chaffed, causing an intermittant misfire over a period of months (each time being cured by switching off for 30 secs to reset the ECU), then eventually literally frying the coil pack! ie something relatively simple to fix, but a pain in the @rse to initially diagnose!
