hi guys,
i am just getting to the point of fitting the coil pack and the HT leads. As i did not take it all apart myself I just wanted to check a few points…
the plug leads are numbered 1 at the alternator end of the engine and number 4 being closest to the gearbox and coil pack, 2 and 3 being ordered between.
The question is are the numbers moulded on the coil pack the correct order to connect the ht leads?
I know it should be but you know, it might not be…
