Hoi everybody,Did anyone allready placed a cat pipe by themself? I mean, not by a dealer?If yes, would like to know how?
HansIt is quite easy - if you can put your car on a ramp. Obviously, a ramp at a car engineer’s is best so you can stand up under the car. After removing the aluminium cover under the engine, the exhaust system is accessible.Good luck.
Disconnect the bracket(s) holding the rear box to th body - it enables you to move the rear box more easily, winkle out the cat and ensure the rep pipe fits well… Also you might want to consider not using the stainless stell bolts supplied as they cold weld (?) themselves on and are a complete b*tch to get off again.
