probably been asked many times before…but what the difference in performance between a 111r and an s2 exige…
many thanks…
Down force and a hard top .
assuming all else is the same (driver, conditions etc)…
on the road no difference, on track the exige will edge it through the corners.
HTH
The tyres, Exige has slightly wider front rims and has the AO48s hence more grip in the dry. Suspension slightly stiffer. Engine, identical.
You mean Hard Force and Down Top!!
The R may even be a shade quicker in a straight line - isnt it lighter?
Yep, but it’ll be only noticed on a stopwatch…
‘slightly’ higher top speed too (not that it would be tested too often)
