Performance Friction Part no?
Anyone know the part number for the PF01’s for the Lotus standard 2-pot caliper ?
01384 240890
Not the part no, but JSR’s number :wink:
Not the most helpful post you’ve ever made Ben :wink:
Nope I don’t, give us a clue? :wink:
Benja on commision ??
:wink:
PF box I found in garage has 7824.97.15.44 if that helps Dave
Thanks mate, perfect
[quote=DaveP]
Not the most helpful post you’ve ever made Ben :wink: [/quote]
I just thought John could supply the p/n the pads or both! I was also of course hoping that if he made a sale he’d knock 50p off my next invoice :wink:
I think the 97 refers to pad compound so if you’re after 01 pads swap these numbers.
[quote=stevegreen]I think the 97 refers to pad compound so if you’re after 01 pads swap these numbers.
Certainly does. The 2 pot shape is one of the few available in loads of compounds. First number is shape, second is compound, third is thickness and last is radial depth. If only every one used part numbers like this, life would be soooooo much easier!!!
01’s for me they seem the best for hard track use :slight_smile:
Who told you that :smiley:
Who told you that :smiley: [/quote]
John and Sean obviously :wink:
