Just took my Exige for a drive today and noticed that every time i went round a roundabout hard or a corner that the parking light would flicker on and off it then goes when on the strights. just woundering if anyone has ever had this before, just had the front off last week to get the heat resistor sorted. im sure that has nothing to go with it.
Can anyone help .
It could be the break fluid level light, when it gets a bit low it flickers was it yellow or red?
just looked at the fluid level and its on max, just took her for another drive, and noticed it only comes on when turning right even without braking. and is red
probably the little micro switch down by the hand brake, got a bit bent and now just triggering with a bit of G when conering.
Solution bend it back !!
Drove all of Snetterton race weekend with the light full on given similar advice about the micro switch from all the guys in the know.
When got home bent it back and light went out
yeah been reading it on lotus talk. people been saying that it could be that or the float is trapped. Is the switch easy to get to? will do it 1st thing in the morning when light.
just had a look at the switchbent it a bit still with no luck, must be the float
The floats also stop acting as floats and fill with fluid which will give this problem, you might need a new one
Does sound like the brake fluid warning light, so will probably be worn pads if your fluid is topped up to max.
pads have been checked, took it 2 lotus this morning and they say that if it only does it without braking and also dry steering i.e full lock to the right when the car is still and only does it round right hand bends or corners its the handbrake cable, it needs to be adjusted so its tight again, he said it happends to their new demo cars and is a common fault, just need to get it adjused again. he game me his word and said not to worrie.
They all do that sir!
Both of my brand new cars did it
thats ok then lol. its not doing it as much now, just a little, so can bear with it lol
