where is the best place to get paint, i need aspen white paint code b113, but it has sparkly bits in it aswell.
Can you not just ring the dealer mate?
im thinking that will be the only place i can get it, just thought someone might of made it elsewhere
any car paint supplier will be able to get it
im finding it hard to track one down in essex area
It’s probably a three pack paint E.G. Ground coat, sparkly coat, then lacked
I’d be surprised if Sinclaire’s couldn’t help.
Brown Borothers in Southend will be able to supply the paint, they mix it all on their site and deliver too. Only problem you might have is being registered to use\store modern paints
none of the numbers for them work ade !!! did try three different numbers you sure they are trading still
This is where I get mine from …
Well it has been a while since I used them, was it this one you tried?
How much paint do you need, I have a paint supplier that may be able to help
I have always used Jawels as there is one close
Looking at the link the closest in now in Chelmsford Nitro…Gotta go there Monday as well to sort my reg plates out
its only to do the roof as we are blending the jamesint roof scoop i wanted to keep it sort of orginal rather then different colour.
