Oil sensor take off
I know there has been a thread about is, but I can’t find it hence a new one.
Just to let you know that we now stock a oil sensor take off for the K-series that actually fits on the car.
It has three 1/8NPT holes and comes with two blanking plugs.
The adapter is to be fitted in between the oil filter and the engine. (this might introduce the need for a smaller oil-filter as some cars already have a take-off installed…)
The adapter can be found here:
Don’t all K’s already have a take-off for the oil cooler already?
The oil filter housing at the VHPD engine hasn�t got a take-off plate. The outlet and inlet to and from the oil cooler are part of the casting. Two 1/8 NPT threaded holes can be found on it. One is used for the oil pressure switch. The other is blanked.
The standard 120BHP engine, don�t use an oil cooler at all.
