Guys with supercharged s2 exiges.
Can you show me your routing for the dipstick pipe? I believe it is different to the N/A version.
Routing you mean just where it is. Its behind the engine move on the drivers side and pull it out through the piping (i have a charged cooled system) but the pipes are similar on the air intake
I am with you on the just pull it out bit but I have a converted car and my dipstick is obscured so I need to work out a new path.
If you remove the dip stick be sure you seat it correctly and have a good seal, it will leak under load and be one of those PITA’s you can do without.
