hi all, not been around for a while.
my exige one of the last na’s has developed an intermittent problem happening randomly on start up.
the car starts, idles at a slightly lower rate than normal. you press the gas and the idle drops to cut out… any ideas?
Me too.
I have also noticed that if I hold the revs at anything up to 4k I get a consistant increase and drop off of up to 250rpm from that point. How about you?
thanks for the reply johnny
not had that - the revs hold steady when the car is running normally.
it’s been fine today - if it happens again i’ll video the problem and see if anyone has any ideas…
I had a very lumpy idle with a standard ECU combined with ITG maxogen and a Larini exhaust. Did the H111 reflash and all the issues disappeared.
Don’t know if that helps at all but do you have any mods to the engine, induction/exhaust?
I have that reflash too
Still…
