Nose badge
An easy one - Exige S2 N/A - bolted on or glued on nose badge? Found answers of both when looking…
Don’t really want to go to the hassle of removing the clam if I don’t need to.
Thanks!
Jonny
I swapped mine to a black/silver one and the original was stuck on (2008 Exige S). Used some fishing line to cut through the glue.
Had my clam off recently and noticed the badge is glued on but does have two alignment pins that go through the clam. So a badge could be bolted on there too.
Recon I’d try the fishing line trick first but remember you will come up against the two pins if it is glued on. So you will have to work the fishing line down from the top and up from the bottom.
Mines an 05 Jon and it the same a Scoobs.
is that the same stuff you use to dangle handbags from when choosing a new car Steve??
:mrgreen:
Ace post !
:clap:
not being sarcastic either. …
Just what the op was wanting
result !
Great - thanks for your help guys - will have a go at it one evening this week
Jonny
Did it come off??
