no dash display
Came back to the car turned ignition on pressed starter button engine started, everything seems to work apart from dash display nothing apart from red alarm light on speedo side any ideas chaps.No rev counter needle, no speedo needle, no fuel gauge, and no warning lights.2010 model year.
have you tried turning the ignition on and off 5 times (I’m lead to believe this resets the ECU…
This happened to my dash (2008) a couple of times, pulled the fuse, re-inserted same and all good - easier than disconnecting the battery which should have the same result.
Hi cisco which fuse did you remove,thanks.By the way do you work in IT,just going from your user name.Cheers Pete.
Was a while ago so don’t remember which worked but pull #7, #8 and #13.
BTW I think the reason this happened, at least once, may have been because I started the car while it was still hooked up to a maintenance charger.
Sorry almost IT illiterate…
Much appreciated cisco it worked thanks for your input.
