Could anyone recommend damper settings for road use? I am currently running 10 clicks from full hard at the front and 13 rear, which seems to be a good compromise. The spring rates are 350/425. It would be interesting to know what other people have found from experimenting.
I’m running 11/14 with 400/500 springs. Its a bit over damped at that to be honest but the springs are still too soft for track work so the stiff shocks go a small way to compensate for that.
Trouble with the Exige is the low ride height and tall wheels c.ock up the suspension geometry so you need to run really stiff to compensate.
Thank you all for the advice. Mark, is there any reason why rear should be stiffer than front? I thought that having rear slightly softer enables you to get better traction out of corners (especially on bumpy country lanes!)
