Nitron question.
While checking around with the front wheels off i noticed that the adjustment spring platform on the Nitron shock is loose, and no way of securing it unlike Ohlins or Proflex etc. Is this right?
Have had a look on the Nitron web site but no info.
Not looked at mine but arnt there small grub screws on that platform to hold it in place.
I would cheek the ride hight as well if it’s been lose for sometime it may have moved on the body.
My Protech Dampers are the same! But no worries as the weight of the car will retain the adjusters in the position… unless you hit full extension…
cannot ever see that happening unless I jack it up!
Theres pilot holes in the spring platform but not threaded.
My Nitrons are under load at all times so dont need grub screws…
