Hi Guys
Here the last news for the K series.
Specific 1.9/2.0K exhaust manifold and concentric clutch slave cylinder
I expect that this helps.
All the best
Vicente
Hi Guys
All the best
Vicente
Very nice!
I might be hitting you up for some stuff in the not too distant future⦠your 2L engines look delicious
Hi Esprit
Yes, this is the last vital part to take all the advantages of 2.0K.
Also it he specific exhaust manifold have some benefics, this is due to the residual gases leaving more efficiently the combustion chamber because the exhaust manifold has the correct size and design to eliminate the most of them, leaving it cleaner, which improves the combustion, increasing the obtained power and torque.
Also the temp decreases in the combustion chamber, gasket head fire rings and piston crown, because the greater the elimination of most of the residual gases that are hot, the cooler it is, allowing a greater filling of clean and fresh air, increasing the reliability of the engine.
All the best
Vicente
