I’ve used a “search” button and now I’m happy.
Sorry for bothering
You will find what you need here…
http://www.dvapower.co.uk/
Yeah thanks!
Just in case the correct answer I’ve found is:
The values are
120-130 thou lift at TDc for the inlet valve (timing is advanced 4 degrees. 1 tooth is 16 degrees, so the advance must be 1/4 of a tooth).
100-110 thou lift at TDC for the exhaust valve (stock)
http://www.exiges.com/ubbz/ubbthreads.php?ubb=showflat&Number=16197&Searchpage=2&Main=2229&Words=Vernier+pulley+101+degree&Search=true#Post16197
http://www.exiges.com/ubbz/ubbthreads.php?ubb=showflat&Number=64474&page=1
