Took the standard belts out and simply disconnecting the sensor to the drivers buckles means the seatbelt warning light and buzzer no longer comes on. The problem I have now is removing and disconnecting the seatbelt pretensioner thingies means the air bag light is now on.
Vert annoying. I called Lotus technical about fitting belts to a car with air bags and told them I plan to remove the standard belts and they said no problem.
My car is in for first service at Nick Whales between Xmas and New Year so will ask them.
does that work? reminds me of a story told during the lotus factory tour where somewhere took the live feed for the pretensioner as a duplicate live for his handsfree… car wouldnt start as pre-check on that circuit failed
All you ecu wants to see is a bit of resistance in the circuit usually created by the firing mech in your pre tensioner/ air bad…the resistor simply ghosts…but it might not work with 3.3 or 6.6…but will with other values…im used to renault’s they use those values.
