You’re getting there then.
Out of interest, if your wing end plates are strong enough, you could try them as they are without bracing them up in any way. A couple of weeks ago I was discussing end plates with Simon McBeath, as I’m thinking about perhaps designing some new ones for mine with some vortex generators. And one interesting thing I found out, was that that slightly flexible but still strong end plates can have an advantage over rigid ones as they create an additional aero effect. Don’t ask me what or how, as I only touched the surface of this idea, but I thought it was quite interesting.
Have you got data for you wing by the way, as close to 400kg at 100mph sounds like a hell of a lot!!! In free air, my SM183 with 120mm 2nd element at 100mph generates about 2300 Newtons and even the SM203 with 170mm 2nd element only generates about 3200 Newtons, and that is a seriously, seriously high downforce wing. I can’t accurately judge from your pictures, but your wing doesn’t look like it has a very exaggerated camber line or a great deal of thickness, which would imply that it isn’t a mega ‘high’ downforce wing. If you want, send me a good, up-close side view picture and I can probably get a fairly accurate idea on what it’s characteristcs might be from Simon. It might give you a better idea on what you’re dealing with.
