well the new exhaust manifold, turbo, external wastegate and other bits and bobs have arrived , so it all go tomorrow night fitting
burt
burt
Looks nice that… Fair play guys…
Pete…
God that�s gorgeous � works so well with the TMR�s too .
Look great Sean
Real pleased the conversion is so far proving the right way to go - sounds just awesome
Fingers crossed Andy, I guess only time will tell.
OK well quite a lot has been happening over the past couple of weeks since my new turbo arrived. Work did stop while I went on holiday for a week at the start of January, but we are getting there now.
The new turbo didn�t end up fitting the way we wanted it. Basically the exhaust and inlet sides of the turbo are now the opposite way around to the original setup, which has meant a lot of new fabrication, for the exhaust and inlet piping.
The pic below shows the new turbo and external waste gate installed
[image]http://img.photobucket.com/albums/0903/SeanBicknell/newturborearview.jpg[/image]
If I put a pic of the original setup below
[image]http://img.photobucket.com/albums/0903/SeanBicknell/IHIengineshot.jpg[/image]
You can see how the exhaust and inlet piping has got to change.
You can also see that the new turbo is quite a lot bigger than the old one. The are several reasons for this.
So all was going well until I noticed that in shipping from the US three of the blades on the inlet side of the turbo are actually bent, which means its knackered and has got to go back. DOH!!!
A new one is now on its way, so hopefully once the pipe work is all done it shouldn�t be too long until it is all mapped and ready to go.
Other new bits that have been fitted are some super juicy 720cc injectors. Thank god I have a friendly MOT man, because at tick over the tester will probably pass out if he walks past the exhaust. Lol. Seriously though, tick over shouldn�t be a problem, it may just be raised to 1,200rpm or something to stop it being too lumpy.
Been working pretty much flat out on the car now since October and with the best will in the world, I bet I am still spannering it in the early hours before the first race. lol
That is going to be RAPID !!!
What is the estimated power per tonne at full boost setting ?
I would think that it will be probably more than a Veyron !!!
Its good to see the versitility of the old VAG lump, more power needed so bolt on another bigger turbo wind the boost up a bit for now, then if even more power is required then on with an even bigger turbo and so on. …
With this new set up, will it have more or less lag than the previous one ?
Its a nice neat install sean, keep up the good work…
We need updates you crazy fool!
LOL
Well its back from Pro alloy and I collected my new turbo last night (the old one was damaged), so work starts in ernest this weekend, before mapping next week.
We are probably going to take the engine out tonight and double check everything, plus I want to change the heat reflective sheet I have on the bulkhead as its a bit of a mess.
I will get some pics up as work progresses.
I have ballast resistors arriving for my new injectors tomorrow (I am running low impedance injectors, so ballast resisitors are required with the Emerald) so fingers crossed by the end of the weekend it will be running again with its new setup.
Then here we come 500… cough… I mean 319.9BHP!!!
Sean…
Is he related to Burt, or did you mean earnest?
Yeah, what he said. You can’t expect me to be able to spell on a Friday, it’s the weekend isn’t it??
No he means his mate Ernest… Sean is also a surgeon in his spare time
A bloody tree surgeon though!
I like trees.
I like trees.
They are hard though.
Bernard
I like trees.
Bernard
Yeah I’m with you there. Thankfully I have never hit one, I have hugged a few though!!
I like trees.
Bernard
Never hit a tree myself, but I did hit a telephone pole in the snow. Wrapped the radiator around the engine, still drove it home though
Bernard
Bernard
Not mid engined then, i assume
come on pet wheres the pics, me and sean did alot of work on saturday.
burt
Yeah whatever…
where’s the proof!
